Why isn’t it safe to tow an electric car?
Few misconception is about EVs, towing situation,
this discussion help us to understand more why :question:
Before going deep into topic, want to introduce myself. I’m a moderator for wa community. This is my first thread, my responsibility to bring new topic for discussion in the Open Talks RangeRants category, always have respect for your suggestions and counter.
Their is lots of official manual from electric car manufacture is available, and you should follow that but in general situation, what will happen if you tow an electric car, can damage some of components, same explained below… :point_down:
Motor Damage
Electric cars have electric motors, which rotate due to magnetic field phenomena. In contrast to that, a generator or dynamo generates electricity from mechanical movement. So, electric motors are used in cars to move the vehicle or convert electrical energy from batteries to mechanical energy, which makes sense. If we tow a car on the ground that means, the car wheels rotate thus the motor rotates and acts like a dynamo. It generates electric energy and sends energy back to the battery. It happens because most electric cars come with a regenerative braking system, which captures energy during braking and feeds it back into the battery. Towing the electric cars on the ground will damage the motor or other electrical components.
Also, most cars come with single or dual-gear transmission which means no clutch system as you have in a normal petrol or diesel car. It is the major concern while towing.
Power Electronics Malfunction
With power electronics, an EV can’t work. It is the centre of the car which controls every sensor, electric power requirement and energy distribution from the battery. This is the most sensitive part, by towing on ground, your car can malfunction or software error can happen.
Recommendation
Many electric car manufacturers advise against towing the vehicle on ground. Some recommended using a flatbed truck instead, as it prevents any damage to any other components. Teslas come with specific towing instructions, such as putting the vehicle in a “neutral” mode or using a flatbed to ensure safe transportation.
Emergency Towing Situation
Always follow the car manufacturer instruction manual and use a truck to tow a car not on ground. Because if it damages other components then it costs you high.
Do share your view on this?
This is something, I don’t know it at all. By the way you mentioned good technical points. :+1:
I want to know, Why no clutch in electric car? and What is does to towing situation?
I am less technical person, but what I know that motor is directly control with accelerator from which speed easily controllable. Clutch is used for gears up and down shift, meanwhile electric cars don’t have gears at all. LOL :rofl: :rofl:
We surly miss the gears shifting in future cars.
But personally I prefer manual shift as it provides bigger control and comfort onnperformance and a beautiful feelingbof drive.
It can not be obtained from autodrive, this is one thing we are missing in electrical vehicle. Atbthe same time the same thing is missing towing of EV problematic. It would require some unique design updates which would overcome this issues and need for autdrive
Lots of people, this concern is real.
